Corner balancing - is it worth it?
Old Oct 25, 2019 | 12:20 PM
range96's Avatar
range96
Originally Posted by badhabit_wb
You're not going to be able to get the rear caster correct with a camber kit. The AMT kit works great but it takes shims in the Uca's to get the caster correct. It also takes shims if you want to fine tune the camber.
Thanks, good to know!
Old Oct 25, 2019 | 03:58 PM
Avanti's Avatar
Avanti
If a pro one needs all the advantages possible within the given rules... if not, spend the effort on something else.
