Will not crank over
Old Oct 30, 2019 | 08:27 PM
bills2017's Avatar
bills2017
Default Will not crank over
My 2017 will not start I have tried everything doors, windows and trunk do not work unless I put the key in the steering column. radio plays all the time info system comes on for a short period then goes blank does anyone have any ideas of whats going on PLEASE HELP
Old Oct 30, 2019 | 09:09 PM
laserdude2215's Avatar
laserdude2215
Battery needs to be replaced.
Old Oct 30, 2019 | 10:30 PM
bills2017's Avatar
bills2017
had battery checked out they said it was okay
Old Oct 31, 2019 | 12:17 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Well, I guess that they are wrong. Sounds like the battery is bad.
Elmer
Old Oct 31, 2019 | 10:00 AM
bills2017's Avatar
bills2017
Had to have it towed to Chevy dealership. they tested battery yesterday afternoon and said battery was good now they want to do diagnostic testing they tried to blame me for trying to jump start the car which I did not do because battery was tested under a load. This is really weird sometimes the doors work then they will not work strange **** happening. Got it to turn on by using remote start but it then wouldnt let me put in gear. turned it off then it wouldn't start again. has anyone ever had this happen to them
Old Oct 31, 2019 | 10:12 AM
c6txvette's Avatar
c6txvette
Sounds like some sort of electrical gremlin. Are there mice where you park her? Maybe the harness got chewed? Check grounds, check terminals and battery connections, finally check the alternator. Alternators can cause some weird **** to happen if they are going bad.
Old Oct 31, 2019 | 03:19 PM
Maxpowers's Avatar
Maxpowers
The C7 is notorious for having battery's test loaded good but they are in fact bad. I suppose you are under warranty and will have the dealer diagnose further but a new quality (non OEM AGM) battery is cheap insurance.
Old Oct 31, 2019 | 05:10 PM
bills2017's Avatar
bills2017
well its Carl Black Chevy and they are trying to blame me for shorting out the BCM which is BS and I would have to pay for the replacement. Do you know how I can personally contact the Chevy warranty department to see if the indeed tried to make a warranty claim and how to dispute the claim. appreciate all your help
Old Oct 31, 2019 | 08:42 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
Just replace the battery.
Let us know when that solves your problem.
And let that dealership know too.
Old Nov 1, 2019 | 02:18 AM
f1reb1rd's Avatar
f1reb1rd
sounds also like a key fob issue. i have had that situation if i for get my key or if my fob was dead then it also would power up for a few then shut off. after getting a new battery in my fob it never came back
Old Nov 1, 2019 | 09:01 AM
eboggs_jkvl
Moderator emeritus
I believe he said the car started with the FOB in the steering column and that means the FOB is fine. The battery might be bad but he says he got 3.0v reading so sounds ok.
BCM is the communication between the car and the FOB. IF the car battery is ok, then the BCM might be the culprit.
Elmer
Old Nov 1, 2019 | 12:00 PM
Maxpowers's Avatar
Maxpowers
On what basis are they saying you did this? How would one even do this?
Old Nov 1, 2019 | 12:22 PM
bills2017's Avatar
bills2017
have not a franken idea how the BCM shorted out. the only thing I did to the car was to check the battery. typical Chevrolet Bull Sh__not wanting to own up to a defective part on warranty. Wish I knew who is the rep in the area.
Old Nov 8, 2019 | 06:08 PM
bills2017's Avatar
bills2017
well update on my car. they replaced the BCM and then all sorts of other codes showed up. now they say the car must have been struck by lightning and other computer parts need to be replaced. they told me to call my insurance company to cover the repairs. **** the nightmare continues.
To Will not crank over
