C7 Stingray gauge and fan problem
Old Nov 3, 2019 | 10:02 AM
Evan Escobar's Avatar
Evan Escobar
1st Gear
Default C7 Stingray gauge and fan problem
Turned on the car just fine , temp gauge doesn’t rise and ac fan stays on even if ac is off , and when I turn the car off fan stays on ? Any help ?
Old Nov 3, 2019 | 01:37 PM
Trevek's Avatar
Trevek
3rd Gear
Coincidence.... Mine just started doing this yesterday. 2014 Base Stingray with Manual Transmission. It also disabled my Rev Matching. Was going to drive it to Chevy in the morning since it drives fine and all gauges look good.
Old Nov 19, 2019 | 10:13 PM
14 Stingray's Avatar
14 Stingray
What did you find? Mine did it tonight
Old Nov 20, 2019 | 01:55 AM
Trevek's Avatar
Trevek
3rd Gear
Thermostat went out. Not an expensive fix and was not delayed by the strike. Also fixed my issue where my ac would sometimes cut out if I had it set too cold.
Old Nov 20, 2019 | 11:25 AM
ersatz928's Avatar
ersatz928
Are you sure that the thermostat went bad? Or was it the Engine Coolant temperature (ECT) sensor?
Old Nov 20, 2019 | 11:39 AM
Trevek's Avatar
Trevek
3rd Gear
Yeah, pulled error code p0128, had the thermostat replaced and all is well again. Under 400 dollar fix.
Old Jan 22, 2022 | 01:41 PM
trcicchi's Avatar
trcicchi
1st Gear
Another data point: 2014 Z51, not getting to temperature, rev limit indication on tach, intermittent loss of temp guage and fan running after the car is turned off. Changed the thermostat, end of problem.
Old Jan 31, 2022 | 10:07 AM
gtpvette's Avatar
gtpvette
Mine started doing same thing this morning.
To C7 Stingray gauge and fan problem
