Transmission fluid temp sensor A
Old Nov 19, 2019 | 08:21 AM
roswell1952's Avatar
roswell1952
Navigator
Default Transmission fluid temp sensor A
I just got a code on my 2015 Corvette saying an issue with the transmission fluid temp sensor A. The driver's display shows the temp in the range of 130-140 under normal driving conditions and the car drives beautifully. The transmission just had the valve body replaced by the dealer with 2 flushes in the last six months. I cleared the code thinking it was a glitch but it came back up 4-5 days later. Does anyone know where the temp sensor is located and can I replace it myself? Cost?
Old Nov 19, 2019 | 10:29 AM
laserdude2215's Avatar
laserdude2215
Take it back to the dealer. The temp sensor is built into the wiring harness inside the transmission.
Old Dec 13, 2019 | 03:13 PM
roswell1952
Navigator
Thanks Laserdude. The dealer confirmed it but I am 2 months past the 5 year cut-off on the transmission warranty. Told me the cost is a little south of $2000.
Old Dec 13, 2019 | 10:35 PM
laserdude2215
No, no, no. They damaged the sensor when they did the valve body replacement. It's on their nickel for a botched repair!
To Transmission fluid temp sensor A
