2/4 valve exhaust question
Old Jan 1, 2020 | 01:43 PM
Sengdemund's Avatar
Sengdemund
Default 2/4 valve exhaust question
Should be an easy question but I’m ignorant on it. Have a 2017 GS w4 valve NPP. Car has AFM permanently disabled (cam). Can I run a 2 valve NPP aftermarket (no AFM valves) with no issues? Common sense says yes, but want to make sure.
Old Jan 1, 2020 | 02:26 PM
Sellout's Avatar
Sellout
The car exercises the AFM valves on startup to test them, and apparently you can't actually pass that test with the actuators disconnected from the valves in the exhaust system. (meaning tied up and out of the way) So you'll get a check engine light. I believe that with the right tuner you can disable the AFM valve check that the car does when starting, along with the codes.
