A8 Manual Mode 2019 LT1
Old Jan 5, 2020 | 03:28 PM
2ndvett01's Avatar
2ndvett01
Default A8 Manual Mode 2019 LT1
When in manual mode do you have to use paddles. I’ve been using the paddles. Haven’t tried it without paddles because I concerned that I might mess up transmission. My question is: will manual mode shift without paddles?
Old Jan 5, 2020 | 05:23 PM
Elk's Avatar
Elk
In manual mode the transmission will hold the current gear until you shift. The transmission will automatically downshift through the gears as the vehicle slows. The transmission will not upshift on its own and you will hit the rev limiter if you do not shift.
All of this, and more, is covered in your manual.
Old Jan 5, 2020 | 07:06 PM
2ndvett01's Avatar
2ndvett01
Thanks Elk
Old Jan 5, 2020 | 07:27 PM
Max Bet's Avatar
Max Bet
The A8 will shift automatically in manual if you hit the limiter. I’ve done it once on the drag strip when I accidentally left it in manual. Got up to third gear before I realized what I did.
To A8 Manual Mode 2019 LT1
