Stealth Mode
Old Jan 10, 2020 | 09:45 AM
Hydrohobo's Avatar
Hydrohobo
Cruising
Default Stealth Mode
What is the difference of stealth mode and tour mode on the exhaust/performance if any?
John
Old Jan 10, 2020 | 12:05 PM
Maxpowers's Avatar
Maxpowers
Stealth is obviously quieter. The power difference is negligible.
Old Jan 10, 2020 | 12:16 PM
Bill Dearborn's Avatar
Bill Dearborn
In Tour Mode the muffler valves will open under certain conditions. In Stealth Mode they will not open unless the driver is operating the engine at full power and high rpms. That is why owners that track their cars on tracks that have noise limits can't just use Stealth mode. Under full power those valves open. Winging the throttle in neutral in the parking lot doesn't produce enough power to open the valves even if you go wide open throttle. It takes less than 5 HP to spin the engine to high rpms in neutral.
Bill
Old Jan 10, 2020 | 02:26 PM
2ndvett01's Avatar
2ndvett01
Where do you access stealth mode?
Old Jan 10, 2020 | 03:13 PM
Hydrohobo's Avatar
Hydrohobo
Cruising
Under “Settings” on the console screen, then driving mode- engine sound management
Old Jan 10, 2020 | 03:14 PM
Hydrohobo's Avatar
Hydrohobo
Cruising
Thanks Bill
Old Jan 10, 2020 | 03:53 PM
2ndvett01's Avatar
2ndvett01
Thanks Hydrohobo
JMII's Avatar
JMII
The early model year C7's don't have stealth mode. For example my 2014 only has AUTO or OFF under Engine Sound Management despite having the NPP system.
To Stealth Mode
