Dash control
Old Jan 14, 2020 | 06:20 AM
Tariq Alshammary's Avatar
Tariq Alshammary
4th Gear
Default Dash control
I bought a new Dash control for my corvette 2014 and i have configured the profile 1 but the problem is once i plug it in The OBDII i can't see any changes in the dash in my display even in navigation mode.
note:
the NPP is opening & closing from the mirror and once i pressed the lock i can heare the sound.
i'm from dubai so my car doesn't have Onstar.
DL1066U
so any one can help
Old Jan 14, 2020 | 06:44 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I had to look this piece of equipment up. Looks interesting but it seems to unusable for 2017 and newer models. Did you download the software from Autometer? http://www.palmerperformance.com/download/dashlogic.exe
That's all I have on this. Sorry. I have EFIlive for my OBDII readings.
Elmer
Old Jan 14, 2020 | 09:17 AM
Moved to C7 Tech.
Old Jan 14, 2020 | 11:11 AM
Jeff V.'s Avatar
Jeff V.
note:
DL1066U
so any one can help
I think the lack of OnStar might be your problem. These dash control units work by 'borrowing' the OnStar turn by turn navigation messages and commands on the car's data network. If your car isn't programmed for OnStar, it probably means those message may be disabled or missing completely. The car is basically ignoring the messages coming from the dash command unit.
I could be wrong, but it might not be possible to fix it.
To Dash control
