Throttle Body
But, WOT is only one throttle position, and the engine is producing power at all throttle positions; ramping off, driveability, smoothness, predictability, etc., come from more power at those throttle positions. We happen to be working right now on a long overdue comprehensive data collection effort that we'll publish here; including simulations, airflow bench test, and load dyno test to put numbers and shape these adjectives. Preliminary results are showing power, and lots of it percentage-wise, at partial throttle. It can also be demonstrated that once you widen and "clean-up" the airflow path, when the TB becomes the restriction, that power in moderate amounts can be achieved at WOT as well.
Please ........
Dave
Now, the only way to change a power curve, whether at WOT or not, is by changing the power values; correct?
Soler Performance LLC
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
