Wrong temperature reading plz help
Old Jan 21, 2020 | 10:48 AM
Muzzi's Avatar
Muzzi
8th Gear
Default Wrong temperature reading plz help
The engine temperature gauge on my 2014 c7 Z51 randomly climbs higher than normal and keeps climbing till I get a message saying "idle engine". This includes the digital reading going past normal aswell, however engine does not seem hot at all and if I immediately reconnect the battery temperature returns to normal and the problem is gone for 1-2 days. This happened twice this week and I daily drive the car with no issues. Could this be a bad temperature sensor? And if not, what could be the issue?
Old Jan 21, 2020 | 11:01 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Nope, you need a new fan and controller. 14's have the problem
Chevrolet Performance for 2014+ Z51
GM 2014 GM #84128343
2015 Z06 600 Watt Radiator fan GM #23376530 discontinued
New 2015 Z06 600 Watt Radiator fan GM #84486698.
https://www.corvetteforum.com/forums...-to-260-a.html
Elmer
Old Jan 21, 2020 | 11:37 AM
eboggs_jkvl
Moderator emeritus
When the temp spikes, just pull over, turn off the engine, open the door to kill the RAP, then restart the engine. See if your fan doesn't come on screaming to cool down the temp.
If this is not the case, then we can chat some more.
Elmer
Old Jan 21, 2020 | 12:17 PM
Muzzi's Avatar
Muzzi
8th Gear
Elmer
It does come on screaming but how to permanently fix the issue? Just replacing the fan and controller will get rid of it?
Old Jan 21, 2020 | 12:37 PM
eboggs_jkvl
Moderator emeritus
If your sysmptoms are as described, then yes. I swapped out my fan in the garage in less than an hour. I think it is post 29 in the thread I linked.
Elmer
Old Feb 2, 2020 | 04:53 PM
Red86Cfour's Avatar
Red86Cfour
From what I understand in reading all these overheating 2014 threads, the problem is the programming of the fan controller, not specifically the fan. The unfortunate part, from what I read, is the newer Z06 fan controller can't be had on its own. I wonder if one were taken from a wrecked donor car, could it be swapped into the stock 2014 fan and fix the problem? Until the time that someone finds this out, the only fix is to update to the Z06 fan and controller, as Elmer and many others have done. Its not terribly expensive and only take an hour or so to do. On the plus side besides actually fixing the problem, you get a more powerful fan in the deal, so its a bit of an upgrade as well as a fix!
Old Feb 2, 2020 | 04:57 PM
eboggs_jkvl
Moderator emeritus
The controller and fan are one unit. The controller is actually located in the fan plug to the electrical system of the car. You can't get the controller all by itself and install it on the existing fan.
Elmer
Old Feb 2, 2020 | 05:18 PM
Muzzi's Avatar
Muzzi
8th Gear
Elmer
​​​​​​I can't seem to find it anywhere online can I have the exact part number for the fan and also I live in the UAE so the dealer sells every part for double the price.
Old Feb 2, 2020 | 05:23 PM
Muzzi's Avatar
Muzzi
8th Gear
I can't find the fan where I live, I guess I'll have to order it. What website would u recommend?
Old Feb 2, 2020 | 05:39 PM
Kracka's Avatar
Kracka
Easy swap on my 2014 Z51. I got my 2015 Z06 600W radiator fan from RockAuto.com and it was direct-fit. I just checked and it's currently $195, plus you can Google search for for 5% off promo code.
To Wrong temperature reading plz help
