RPI Splitter/ GM Deflector?
Old Jan 23, 2020 | 01:30 PM
Dkroese's Avatar
Dkroese
Default RPI Splitter/ GM Deflector?
Had just got my RPI C7-Z107
C7 Corvette Stingray Z06 Painted Front Splitter and was curious if a GM (23163400) Front deflector would fit it. I understand would require some drilling etc but was wanting to hear if someone has worked with this splitter combo. I had looked on the forum and didnt see it, for fear of repeating, so here we go
Old Jan 26, 2020 | 12:36 AM
Avanti's Avatar
Avanti
Have you asked RPI?
Old Jan 27, 2020 | 03:10 PM
Dkroese's Avatar
Dkroese
Yes they said they didnt know
Old Jan 27, 2020 | 09:57 PM
96GS#007's Avatar
96GS#007
The OEM splitter has an added lip underneath that is shaped, drilled, and uses u-nuts that the bolts attach to. All they need to do is look at the underside of the splitter to see if it has the added lip.
The below pic is the underside of mine. You can clearly see the added mounting bolts. If RPI can't flip the splitter over that they sell and see if there's a lip suitable for those bolts....it won't work. C7Carbon, I *think* ACS, APR Performance, and Katech sell splitters that will work. C7Carbon is probably the cheapest and will require some work with a Dremel tool to make it work. APR and Katech will be OEM equivalent in quality and cost. With these parts, you Definitely get what you pay for.
Old Jan 28, 2020 | 10:23 AM
Dkroese's Avatar
Dkroese
Thank you I will have to look at it after I mount it and fit it. Your pic helps alot thank you
To RPI Splitter/ GM Deflector?
