Oxygen Sensor replacement
Old Feb 3, 2020 | 02:45 PM
Richard Sawkins's Avatar
Richard Sawkins
Default Oxygen Sensor replacement
I have looked, and not found much. Has anyone replaced the upstream oxygen sensors. I have a P015B code. Its a 2016 Z51 M7. If anyone has, do you have any tips or tricks to assist in replacing one or both of them. I cannot even find an assembly drawing showing where they are located.
Thanks in advance
Richard
Old Feb 3, 2020 | 04:18 PM
2019GSTX's Avatar
2019GSTX
Lurker
St. Jude Donor '19-'20
Should be located in the downpipes coming off the head, just before and after the cats. Look at items 26, 27 and 31, 32
I would soak them overnite and then get ya a socket that is made for removing them.
Old Jan 3, 2024 | 01:07 AM
jclumbano's Avatar
jclumbano
7th Gear
Hello Richard. Did you have to replace the sensors?
Old May 3, 2024 | 12:10 AM
Yeezuss's Avatar
Yeezuss
Did you end up fixing the code by replacing the sensors? Having the same issue
Old May 5, 2024 | 09:01 AM
Tinkertech's Avatar
Tinkertech
Always use GM OEM O2 sensors, thank me latter.
Old May 8, 2024 | 07:24 PM
Chazzmania's Avatar
Chazzmania
You'll need to unplug em from the harness and use a 02 sensor socket.
Old Jan 12, 2026 | 03:07 AM
Argonitight's Avatar
Argonitight
currently trying to remove upstream B2 S1 Sensor. its so stuck on there. it snapped my Sensor socket in half with a breaker bar. i have Codes P0050 and P0051... and P0004. amazingly there are no C7 videos on Youtube on the best way to remove these sensors. im shocked.
Old Jan 18, 2026 | 09:07 PM
aklim's Avatar
aklim
If it is that stuck, maybe a hot flame? If you are not comfortable with that or unable to do it, get a professional.
Old Jan 19, 2026 | 03:02 PM
9sec's Avatar
9sec
could always remove the downpipes and get better leverage
To Oxygen Sensor replacement
