TPMS question
Old Feb 10, 2020 | 01:08 AM
mmorse's Avatar
mmorse
Default TPMS question
can someone give me the part number for tpms sensors for a 2014 premiere edition corvette and the best place to get them
Old Feb 10, 2020 | 01:56 PM
JMII's Avatar
JMII
Whatever Tire Rack sent me worked. On the invoice they are listed as "433MHz Tire Pressure Sensor" $43.00
No relearn procedure or anything, I started driving and after a few miles the values populated onto the dash.
Old Feb 10, 2020 | 04:14 PM
mmorse's Avatar
mmorse
hmm, that’s interesting. everything i read is the 443mhz is export cars only. all the domestic cars are 315mhz. when i changed the sensors in my c6, it was 315, not 443. perhaps with c7, they settled on 443 for all cars. so you are saying that all you had to do was install them and the car automatically recognized then after a few miles. that’s a lot easier than what they had to do on my c6.
Old Feb 10, 2020 | 04:35 PM
mmorse's Avatar
mmorse
just called tire rack and they told me they don’t sell auto programmable sensors. they only sell OEM type sensors. are you sure you got yours from tire rack?
Old Feb 10, 2020 | 09:36 PM
Bill Dearborn's Avatar
Bill Dearborn
First, make sure you purchase OEM sensors. Aftermarket sensors are more prone to problems. You may pay more but the lack of issues makes it worthwhile. Check various sources for sensor prices. In addition to Tire Rack, The House of Wheels a forum sponsor in Florida sells OEM sensors.
Bill
Old Feb 10, 2020 | 11:11 PM
Kracka's Avatar
Kracka
RockAuto.com sells the OEM ones for about $32/each. Aftermarket brand for about $10 less. I always use them for ACDelco parts.
Old Feb 10, 2020 | 11:59 PM
RacerRik's Avatar
RacerRik
JMII is correct. All C7 Corvettes use 433MHz senors. The OEM part number is 13581560. The OEM sensor is made for AC/Delco - GM by Schrader. Schrader also sells the same sensor with a part number of 20223. TireRack sells the Schrader 20223.
One difference in these sensors is that the 20223 will work on 2014 to 2019 C7s. The OEM 13581560 part number will only work on 2014 to 2017 C7s. The 2018 and 2019 C7s switched to a new OEM part number of 13598775. The 20223 part is backwards compatible for all C7s.
RockAuto has the 20223 part for only $22.79. I doubt you will beat that price.
Old Feb 11, 2020 | 04:20 AM
mmorse's Avatar
mmorse
thx everybody, this is great info!
Old Feb 11, 2020 | 10:57 AM
JMII's Avatar
JMII
For sure. Ordered new wheels and tires... TPMS were part of the package and I did nothing but put the wheels on the car and drive away
Old Feb 15, 2020 | 02:01 PM
Red86Cfour's Avatar
Red86Cfour
Depended on the year C6. I think after 08 the sensors changed. Also on the C6 there was a procedure that required a TPMS programming tool that made the sensor at each individual wheel ping so the computer would know which sensor was where. Fortunately the C7 doesn't require that and is smart enough to figure out what sensor is where. That is, assuming the correct sensors are installed on the wheels.
To TPMS question
