C7 z51
Old Feb 10, 2020 | 03:32 PM
bolevine's Avatar
bolevine
Default Need suggestions on replacing rotors and brake pads for C7 Z51
I'm looking to upgrade my brake rotors to ones that don't rust every time you wash the vehicle, and I want them to be drilled and slotted. also I would like the center to be painted black. I also want to replace the brake pads to ones that don't leave so much dust. Every time I take the car out, the wheels look like they were never cleaned. I would appreciate anyone's feedback on which brands you recommend and where you got them. Thanks for your help
Last edited by bolevine; Feb 10, 2020 at 07:20 PM. Reason: Need better description
Old Feb 11, 2020 | 11:03 AM
JMII's Avatar
JMII
The rotors are going to rust nothing you can do about that.
DBA T3 ClubSpec 4000 rotors have black painted hats and are just slotted (not drilled). I use PowerStop Z23 pads, no dust.
Old Feb 11, 2020 | 11:13 AM
Maxpowers's Avatar
Maxpowers
Iron rotors rust. After you wash the car, drive around the block and you won't have an issue with rust on the rotor surface.
Old Feb 11, 2020 | 11:41 AM
427C62013A's Avatar
427C62013A
http://store.corvetteforum.com/p-117...ck-c7-z51.aspx
Old Feb 15, 2020 | 01:56 PM
Red86Cfour's Avatar
Red86Cfour
carbon fiber rotors won't rust......
Old Feb 16, 2020 | 10:14 AM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
The Carbotech1521 brake pads are a high performance low dust street compound.100% non-corrosive dust will not harm your wheels, paint or rotors. Carbotech brake pads are 100% made in the USA and are equipped with NRS Technology you can read more about that here http://www.nrsbrakes.com/ Carbotech brake pads can be ordered online @ http://ampdautosport.com/brake-pads/corvette/ or call me at 216-780-8825. The part numbers you need are front CT1001 and rear CT1718 these are listed under C7 section..Use promo code z28 at check out to receive your forum discount. .
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known fo- its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Old Feb 16, 2020 | 06:33 PM
Avanti's Avatar
Avanti
That all ya want? Base St'rays' are specially treated and don't rust... only C7 so equipped!
To C7 z51
