A8 to manual
Old Feb 11, 2020 | 04:36 PM
2ndvett01's Avatar
2ndvett01
Default A8 to manual
When driving in D does the AFM disengage when shift paddles are used?
Old Feb 11, 2020 | 04:40 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Yes, it stays in V8 with the gear shift in manual. Hm... If you keep the gear shift showing the "M" but it reverts when it drops back to "D" for sure
Elmer
Old Feb 11, 2020 | 04:51 PM
2ndvett01's Avatar
2ndvett01
I meant using paddles when gear shift is in D.
Old Feb 11, 2020 | 04:53 PM
eboggs_jkvl
Moderator emeritus
When you are in D and you start slapping paddles, look down at the console and it'll be showing M BUT you're still in D. It times out after you leave the paddles alone and switches back to D. The shifter itself never moves but the indicator shows the D/M/D change.
Elmer
To A8 to manual
