Need to trailer my C7-Z06 to track events, need tie-down advice. I have a 2280 Aluma trailed with multiple tie-down options. What is the best straps and brackets to use?
Hardly a topic more debated! I have an aluma trailer and found a great thread 2 years ago with a system i have had success implementing. https://rennlist.com/forums/racing-a...tie-downs.html
I added pass-thru d rings about 12" ahead of front tires to promote ideal strap angle and ensure proper bumper clearance and clipped the ratchets to the inset d rings that came on the trailer.
Ensure that you pass the strap thru a rim opening that does NOT have a valve stem.
I have airline track on my trailer and use Mac's tie downs that fit over the tires. I use a featherlite 3182 trailer so it came with the airline track but you can have it welded to your trailer.
