Weird problem on my 2019 Stingray
The radio continued to play and would not shut off. Got back in the car, pressed brake and clutch and tried to start the car. It turned once and shut down. Not like it couldn't start. More like I took my finger off the start button in the middle of the start, which I didn't. Tried again, same thing. And a third time! Nervous now, I tried once more and the car started fine and ran fine. Shut it off and all was normal. So...do I have a problem or no? Any idea what caused this?
Just turning off the motor activates Retained Accessory Power (RAP). Radio and electrical should shut off in 10 min.
From the 2019 manual:
ACC/ACCESSORY (Amber
Indicator Light) : This mode allows
the use of some electrical
accessories when the engine is off.
With the ignition off, pressing the
button one time without the brake
pedal applied will place the ignition
system in ACC/ACCESSORY.
The ignition will switch from ACC/
ACCESSORY to off after
five minutes to prevent battery
rundown.
Retained Accessory
Power (RAP)
Some vehicle accessories may be
used after the ignition is turned off.
The power windows and sunroof,
if equipped, will continue to work for
up to 10 minutes or until any door is
opened.
The infotainment system will
continue to work for 10 minutes,
until the driver door is opened,
or until the ignition is turned on or
placed in ACC/ACCESSORY
Ron
Sometimes you need to open the driver's door to clear RAP mode. The car can be too smart for itself sometimes...
Ron
Op may have gotten himself into service mode. This would explain why the engine would not start...
It is ALL in the OWNER'S MANUAL! Search for IGNITION POSITIONS.
Service Mode
This power mode is available for
service and diagnostics, and to
verify the proper operation of the
malfunction indicator lamp as may
be required for emission inspection
purposes. With the vehicle off, and
the brake pedal not applied,
pressing and holding ENGINE
START/STOP for more than
five seconds will place the vehicle in
Service Mode. The instruments and
audio systems will operate as they
do in ON/RUN, but the vehicle will
not be able to be driven. The engine
will not start in Service Mode. Press
ENGINE START/STOP again to turn
the vehicle off.
