Heater Blowing Cold Air
Old Mar 1, 2020 | 12:10 PM
jforce's Avatar
jforce
Default Heater Blowing Cold Air
Help!!!! I have a 2016 Singray Base Heater is blowing cold Air. Temp outside it mid 50s temp in car set at 73. How do I fix This?
Old Mar 2, 2020 | 09:41 PM
BrunoTheMellow's Avatar
BrunoTheMellow
What's your coolant temp? Heater runs off coolant.
Old Mar 3, 2020 | 07:18 AM
BlueDevilZ51's Avatar
BlueDevilZ51
Check your coolant level
Old Mar 3, 2020 | 09:44 AM
ClothSeats's Avatar
ClothSeats
Pull your cabin air filter to see if something is blocking air flow through it. This is a location where mice like to build nests.
Old Mar 3, 2020 | 10:39 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
How far back is your seat? Do you have it all the way back? I read yesterday that having the seat pinned all the way back can cause cold air out of the heater. Don't laugh! It was true!
Elmer
Old Mar 3, 2020 | 11:20 AM
rjacobs's Avatar
rjacobs
crank the temp to max and see what it does.
I like to keep mine set around that same 73 give or take and on A/C it seems to do ok, but when the wife and I want heat we have to kick it up to 76 or 77 to feel comfortable.
To Heater Blowing Cold Air
