Gear Oil C7
my transmission shifts hard, i have already tried redline D4 and royal purple it has not improved much. Has anyone tried the Ravenol MTF2 here and can say something about it?
greetings
1. Shifter alignment procedure (link below)
2. Clutch fluid flush
https://www.corvetteforum.com/forums...procedure.html
Depends on what you've driven before as a point of comparison. I feel the shifter effort could stand to be reduced on the C7. I learned to drive stick in the 80s using Hondas and they flip into gear with minimal effort. Later on I got a VW that had a very rubbery feel to its shifts. Then my Nissan had a very positive feel that went it with a snap. Ever car is different.
I test drove three C7s because based on the first one I thought something was wrong. Turns out it was totally normal... and I just had to get used to it.
