Long tubes and catless x-pipe question
Old Mar 2, 2020 | 07:23 AM
GHOSTRACER's Avatar
GHOSTRACER
Default Long tubes and catless x-pipe question
I’m installing an A&A kit and meth injection this week and considering long tubes also. Pulling memories from my LS1 F Body days, I had a system that had drop out high flow cats that could be replaced with a straight pipe in a matter of minutes. Without the cats, the exhaust was really raspy and the fumes were really bad. My question, hows the exhaust tone (stock mufflers) and how bad are the fumes? Any significant HP/torque difference between catted vs non? TY.
Old Mar 2, 2020 | 11:17 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
I can't answer on the tone with stock mufflers as I have a set of corsa on mine but with no cats I have the typical stinky exhaust. So if you don't want the smell I would consider a set of high flow cats just make sure they are compatible with your fi set up. Talk to some of the guys over in the fi section of the forum and see what they are using for their set ups.
Old Mar 3, 2020 | 02:51 PM
Dane@LGmotorsports's Avatar
Dane@LGmotorsports
Premium Supporting Vendor
Our system has the type of high flow cats that can be swapped out for off road pipes easily.
To Long tubes and catless x-pipe question
