C7 Corvette problem
Old Apr 14, 2020 | 03:36 PM
Miguel Victoria's Avatar
Miguel Victoria
1st Gear
Default C7 Corvette problem
My 2015 corvette has the check engine light for an evap emission code but says it’s a circuit . Also gives me a code about oil pressure.What can I change to fix it? Thanks
Old Apr 14, 2020 | 07:03 PM
Avanti's Avatar
Avanti
Still have the original battery? It gets wonky and all sorts of things happen, many times ones that do not seem logically related.
Old Apr 15, 2020 | 09:56 AM
JUICED1's Avatar
0JUICED1
Former Vendor
Keep an eye on your oil pressure because if you are having a real issue there it can be catastrophic. Reset the codes and see if they come back. Like mentioned above they can get triggered by a low battery but you don't want to assume that. If they are coming back you will want to look into both sensors, maybe they share a common ground or they might need to be replaced.
To C7 Corvette problem
