Code # P2635
Old Apr 27, 2020 | 09:06 PM
Kazman1960's Avatar
Kazman1960
Default Code # P2635
So on Sunday , a few guys decided to go for a decent length run . Air temps were around 10 degrees , cold but OK . The car was pulling like a freight train . On the first part of the run we attained some high speed runs and all was good . We stopped for some food for half hour , on the second part of the run i decided to try a top speed run . As i said the cold air was great for the car . Well i hit the fastest speed yet ( for me that is ) when i slowed down i saw the CEL come on , any ideas to what it could be ?
Old Apr 27, 2020 | 11:48 PM
laserdude2215's Avatar
laserdude2215
Your low pressure fuel pump (in the tank) could not keep up!
Old Apr 28, 2020 | 06:15 AM
Kazman1960's Avatar
Kazman1960
Please excuse my lack of knowledge but when i had the car worked on two summers back , i had a Low side fuel system installed , is this different to the in tank pump ?
Old Nov 20, 2023 | 03:02 PM
Eli-Z06's Avatar
Eli-Z06
Default check engine light for fuel pump code p2635
just wondering what was the outcome cuz my car is doing the same thing... thanks for the info
Old Nov 20, 2023 | 08:45 PM
Kazman1960's Avatar
Kazman1960
Mechanical fuel pump was busted . Replaced with new one which i do believe are the same ones that are used in the ZR1 .
After the tuner installed and had to re tune as the pump was pushing way more fuel .
I could even tell the difference when i picked up the car after he fixed it .
Old Apr 20, 2026 | 10:21 PM
Szabol's Avatar
Szabol
I wonder if you have a Soler Performance interface can lead to this issue?
Szabol's Avatar
Szabol
Also, did you see a P018C error code?
Old Apr 21, 2026 | 06:37 PM
Kazman1960's Avatar
Kazman1960
No other codes other than the original one mentioned 6 years ago .
Since the new pump was installed and the car re tuned its been working great again .
To Code # P2635
