Brake Pads
Old May 9, 2020 | 12:39 PM
slicknruben's Avatar
slicknruben
Default Brake Pads
I went to order Power Stop Z26 Extreme Performance Brake Pads for my 2014 Z51 package and there is a choice between which rotors the car came with. Standard or re-designed for better cooling? Anyone have an idea how to tell which one came with the car? All the build sheet has is J55 and no mention of anything about a re-design. Thanks in advance.
Old May 9, 2020 | 04:35 PM
FKING1's Avatar
FKING1
Don't think it makes a difference.
I have Z26 on my 2015 Z51 and just ordered for the standard rotors.
Old May 9, 2020 | 05:19 PM
slicknruben
Thanks. I just ordered them.
Old May 9, 2020 | 05:35 PM
Kracka's Avatar
Kracka
Which rotor doesn't matter so no big deal.
Old May 9, 2020 | 07:10 PM
wrecker3's Avatar
wrecker3
Power Stop Z26 pads could turn your brown !!!
Old May 10, 2020 | 01:13 AM
Kracka's Avatar
Kracka
17k miles on my Z26 pads and they've been great.
Old May 10, 2020 | 04:29 PM
FKING1's Avatar
FKING1
Agree, same here
Old May 11, 2020 | 12:01 PM
JMII's Avatar
JMII
Doesn't matter which rotors you have - the improved ones just replaced the troublesome (prone to warping) fake two pieces originals.
More info: http://www.corvetteactioncenter.com/...pply-1270.html
Just as an FYI - the Z51 and base brakes use the same pad size & shape. The rotor is larger, but the pad sweep area is the same, its just pushed out an 1/2" further.
No brown rotors with the Z23 pads on my Z51.
Old May 11, 2020 | 01:49 PM
slicknruben
Thanks for the information.
Old May 11, 2020 | 04:43 PM
MeanRay1's Avatar
MeanRay1
Yep! mine turned brown. I changed out the rotors and went with Carbontech Pads..
To Brake Pads
