Cylinder 8 misfire
Elmer
Fuel issue would not just be a cylinder #8 misfire code. Fuel would spread the love around and many cylinders would be singing the chorus. If, as stated, it's #8 that is mad, then it's something that is associated with #8.
The posts in here have covered the most common and easy to fix scenarios. If all our suggestions don't help, go to the dealer.
Elmer
**UPDATE** 10/29/20
Checked both valve covers all over with a stethoscope and didn't hear anything that stood out. The ticking noise was not very loud when parked in the garage at idle or increasing RPMs. When a load is applied at very low speed, the ticking noise is very noticeable. I did run across a bulletin from General Motors (PIP5395B) for a ticking/rattle/buzz noise that apparently comes from the HPFP. The bulletin says to put a stethoscope on in fuel line at the motor going to the HPFP. I'll try that tonight and see what I hear. The other thing I am going to try is to jack up the rear end and put the car in drive and see if that makes the ticking noise louder so I can pin point it. Other option is to find a dyno to help put load on the motor.
**UPDATE** 11/1/20
I had a friend drive the car slowly so the car would be under load while I sat in the engine bay and listened with a stethoscope all over. I could not hear any change in noise anywhere. He could still hear the noise inside the car. After looking into it further, it is more noticeable when listening under the car. Going to put it up on stands and dig in a little further today. I can say for sure the the noise does not change louder or softer with the clutch pedal in or out.
**UPDATE** 11/9/20
I've checked all over and under the car and cannot pin point the ticking noise. I'm hoping its an injector. I pulled the supercharger off this weekend and found a few things.
1.) There was coolant on the intake side of 1-3-5-7 but not the other side. I found that it is coming from the cooling brick. I am going to do a leak down on the system as it is now tonight but suspect a bad O-ring. I'm going to order all new O-rings for both cooling bricks. After I replace the O-rings, I'll do another leak down. I'll post the results.
2.) There was a lot of what looks to be oil on #1 injector as well as some blow back past the injector. I never had any issue with #1. I bought a leak down tester and I'm going to do a leak down on all cylinders Tuesday evening. I'll post the results.
3.) I did not see anything abnormal on 2-4-6-8 side.
4.) Once I complete the cylinder leak down I will be sending the injectors off to be tested and cleaned. I'll replace any that are bad. I am sending them to Fuel Injector Clinic.
**UPDATE** 11/18/20
Coolant leak was not an O-ring, it is a leaking intercooler brick which is bad news because they are not sold anywhere. I few places sell aftermarket ones for $1,800. Still looking for one. Leak down test show 3 bad cylinders (6, 7 & 8) leaking past the rings. Going to have to pull the motor and rebuild. Set up with shop to start the work in January. Worst news possible I guess. Injectors have been sent off to be inspected to see if that was the root cause. Other possibility is the leaking intercooler brick caused it. No fluid came out of the bricks when I removed them which is not right. I'll post another update when I have some new information.
