Noob question. How do I remove this?
May 22, 2020 | 09:57 PM
Hello,
I'm replacing Spark Plugs & I need to remove the fuse box. What is the proper way to remove the item i'm pointing at? Thank you.
May 22, 2020 | 10:47 PM
Quote:
Originally Posted by
BLahdo_c7z06
Hello,
pop that clip up and remove the nut underneath it. Ensure the battery is disconnected first.
May 22, 2020 | 11:01 PM
The nut is difficult to remove without breaking the fuse box!!!!
Push the cover toward the rear of the car and rotate to the driver's side.
Maybe someone who has removed this or can find the old thread will chime in.
Plugs are supposed to last 100k miles, so why?
GL
Ron
May 22, 2020 | 11:11 PM
Here's a thread with some info. Using an impact wrench to remove the nut is recommended. Also look at the link noted in the thread.
https://www.corvetteforum.com/forums...lug-wires.html
Ron
May 23, 2020 | 03:09 AM
Got it! Thanks guys. Plugs turned out to be pretty easy once you get cyl 8 & 7 out of the way
