Corsa long tubes
Old May 26, 2020 | 03:41 PM
Thuggishcoot42's Avatar
Thuggishcoot42
Default Corsa long tubes
Hello guys, So I've been looking at headers for about a week I've decided to go with Ckrsa long tube headers..
but what is the best website to buy them from... I figured Corsa I was going to buy from Texas but their number does not work any recomendations?
Also LTH cat delete no modifications needed rightM says paired with the corsa axle back i can expect 41 HP, and i have that axle back but ive noticed a lot of headers require their own x pipe i have factory any issues ill run into? Thanks
https://www.texas-speed.com/p-9043-corsa-14-20-c7-base-z06-long-tube-headers-1875-x-30-catless-xtreme-sound-level.aspx
https://www.corsaperformance.com/18859927/checkouts/f4c138aabcd69a4dca4b3f66afba803e?skip_sh opify_pay=true&locale=en
Old May 26, 2020 | 04:32 PM
ss2z06's Avatar
ss2z06
No matter who you go with you'll need an x pipe. I would suggest american racing or kooks for the long tube headers. I've never seen anyone run corsa headers. Their catback sounds great but you may want to go elsewhere for the headers. If you do a search there is a reason why people runs ARH or kooks.
Old May 26, 2020 | 05:57 PM
Thuggishcoot42
thanks for the reply dude, why do people hate Corsa headers? So I'm forced to get an x pipe? Damn that suck, so if I do get a x pip/LTH will the xpipe fit to my corsa axle back? I want to keep it, thanks.
Old May 26, 2020 | 08:02 PM
ss2z06's Avatar
ss2z06
There's nothing special about the corsa axle back system. Its the same connection as the oe or other systems. The long tubes with their xpipe will work with them. The long tubes should come with the xpipe. At least the ARH or kooks do.
Old May 26, 2020 | 08:13 PM
Thuggishcoot42
thanks dude, can you give me a link?
Old May 27, 2020 | 11:20 AM
ss2z06's Avatar
ss2z06
https://americanracingheaders.com/collections/corvette
https://kooksheaders.com/my-vehicle/...es/All%20Sizes
Old May 27, 2020 | 08:31 PM
Garyev's Avatar
Garyev
5th Gear
I have the Corsa headers. You have to use the Corsa x pipe. I have the helix x with extreme axel back. Love them
Old May 27, 2020 | 08:40 PM
Thuggishcoot42
did you buy them as a set? Can you give me the link where you purchased them ?
Old May 28, 2020 | 07:23 AM
-ZEEOHSIX-'s Avatar
-ZEEOHSIX-
So the Corsa long tube headers bolt right up to the standard Corsa double-x pipe they sold for a good while there? I thought that the Corsa double-x pipe wouldn't work with any headers besides the stock manifolds.
Old May 28, 2020 | 09:01 AM
Garyev's Avatar
Garyev
5th Gear
I first purchased the X pipe, then later purchased the LTH and axel back.
LMPerforamce.com. I have used them for all my parts. Be sure and check for discounts before you hit the buy button.
Old May 28, 2020 | 09:28 AM
Internets_Ninja's Avatar
Internets_Ninja
ARH or Kooks won't let you down.
Old May 28, 2020 | 10:42 AM
Thuggishcoot42
Hey thanks I am at a loss...
This is the website you recommended, but it does mot say these are the extreme Corsa LTH like it does on this website so i am kimd of lost as what to do...
These are the ones, ive been lookong at.. and the ones i want so idk if they are the same or what, i am rather confused
Old May 28, 2020 | 11:36 AM
MerakiAutoworks's Avatar
MerakiAutoworks
Supporting Vendor
Hey,
Text us at 213 394 2886 or email us at info@merakiautoworks.com
We can get you taken care of with ARH, Kooks or Corsa. If you want to do Corsa we can get you setup with the right setup. Just need their x pipe and we have that in stock as well.
-Josh
Old May 28, 2020 | 03:35 PM
Garyev's Avatar
Garyev
5th Gear
Buy sheet attached my car 2019 zo6.
Old May 28, 2020 | 03:49 PM
Thuggishcoot42
I guess I'll go with it, did you receive them yet?
Old May 28, 2020 | 07:15 PM
cstapp99's Avatar
cstapp99
https://www.texas-speed.com/p-9043-c...und-level.aspx
https://www.corsaperformance.com/188...true&locale=en
The Corsa headers will bolt up to the factory mid pipe or the Corsa X pipe. Both are dimensionally the same. Plenty of bad information out there, but this is the truth.
Old May 28, 2020 | 07:27 PM
Thuggishcoot42
Hey, is this a proven truth? B.c all I want is the LTH....even when I called they said it requires their x pipe...if this is true ima buy the headers today! Thanks dude
To Corsa long tubes
Old May 28, 2020 | 07:39 PM
cstapp99's Avatar
cstapp99
Yes it’s fact. Consider this - the Corsa double helix X pipe was made to bolt up to your factory system (manifolds in the front and axle-backs in the rear.) The headers were then built to mate up to the Corsa X pipe. It’s all dimensionally the same. I called them when I was shopping and they confirmed for me that they will fit with the stock mid pipe. Make your order with confidence.
Old May 28, 2020 | 07:54 PM
Thuggishcoot42
thanks dude, ima go buy the Corsa LTH now!
Old May 29, 2020 | 08:41 AM
-ZEEOHSIX-'s Avatar
-ZEEOHSIX-
So I found this description online of one of their headers:
Corsa 1-7/8 Inch Long Tube Headers - C7 Corvette Stingray. Complete the Corsa Exhaust System on your C7 Corvette Stingray with a set of Off Road Headers. Manufactured with High Grade Stainless Steel, these Headers feature 1-7/8 Primaries and a Full 3" Race Style Merge Collectors. Designed and engineered to mate directly to Corsa's world famous Double Helixx X-Pipe (PN-14761) When it comes to Corvette Exhaust Systems, Corsa Quality is hard to beat. 16004
But the note right under it says:
Product Note: Designed to mate to Corsa X-Pipe only. Will not work with OEM or other Aftermarket X-Pipes
Which is super confusing. Since the Corsa X-Pipe was designed to work with the stock manifolds. Oh well, I guess a phone call to double check is warranted. But, if this is true, it looks like I'm getting their headers.
https://www.corvettepartsandaccessor...ders-1-7-8-z06
