Magnetic shock replacement
I have a 2017 Grand Sport Convertible, 15,000 miles, bought used last year. It was a "Certified" used car. Dealer doing oil change today told me that all 4 shocks are leaking. He actually showed me, but I have not ever noticed any leaks on the ground, garage floor, or lift it lives on. Then was told that parts alone will be $2700. I've been trying to research and saw a lot about seepage vs. leaking and failure. The ride is not compromised at all, and I have no alerts or codes showing up. What is the likelihood of all 4 shocks leaking at the same time? Is $2700 realistic?
I am going to completely wipe everything down, then re-check for leaks. Any other advice? Thanks in advance.
Normal, if it is just a little film around the shock body that is normal. Mine does it on three of the four.
