Wheel spacers?
Old Jun 21, 2020 | 03:22 PM
All Stock Ls2's Avatar
All Stock Ls2
Default Wheel spacers?
Hello everybody,
I was wondering if anybody here had good angled pictures of what 6mm and 8mm wheel spacers on the OEM Z51 wheels looked like? I’m a bit it a purist and don’t want aftermarket wheels. However, I don’t like the sunken in look of the C7 wheels. I already have a clear bra on and I understand putting wheel spacers will make me run through the clear bras at a much faster rate. It’s an evil that I am ok living with. Thanks in advance!
Old Jun 22, 2020 | 07:57 AM
CraigStu's Avatar
CraigStu
Before going too far I'd look into how much wheel stud you will have for the nut w/ the spacer. The studs don't look every long to me. You could do a quick mockup w/ stacks of fender washers. Also look at the depth of the wheel centering ring on the hub. How effective will it be w/ an 8mm spacer.
Old Jun 22, 2020 | 04:17 PM
ErnieN85's Avatar
ErnieN85
works fine with 6MM space
however I do not have stock wheels & tires now so no pics I have 19X12 & 305's if you want pictures of that
To Wheel spacers?
