Removable top
Old Jun 25, 2020 | 10:10 AM
2ndvett01's Avatar
2ndvett01
Default Removable top
2019 1lt coupe: does anyone know how to adjust the the front latch tension for the coupe top? Driver side latch has less tension than passenger side latch. Resulting (I think it’s the cause) in the driver side top alignment 5 mm further back than the passenger side. The top rear alignment is right on
Old Jun 25, 2020 | 09:23 PM
black.z51.c6's Avatar
black.z51.c6
make sure the alignment posts are tightened... my passenger side was a few turns loose, 17mm combination wrench, used the open end side
Old Jun 25, 2020 | 09:25 PM
black.z51.c6
Also, i had a ton of rattles, so i put heat shrink tubing over the posts to stop the rattle.seems like it worked. Also you can tighten the back clamp by loosening the set screw with a 5/64 allen wrench and turning the hook in 1 turn
Old Jun 26, 2020 | 08:48 AM
2ndvett01's Avatar
2ndvett01
Thanks. Looks like just need to make sure everything is tight.
Old Jun 28, 2020 | 03:45 PM
Avanti's Avatar
Avanti
5mm(!) is a LOT. I've never seen anything like that. I'd think that something has come loose. All the best.
To Removable top
