2014 steering column tilt control
So - could be the connector, telescope switch, telescope position sensors, ground, and least likely the control module or other electronics.
If you have 2/3LT the tilt and telescope may be saved different between memory settings and exit. See if the memory buttons will make the wheel move - if so, this points you to the manual tilt / tele switch and wiring.
This may help:
The steering column has a tilt/telescoping control system that consists of an steering column position
control module capable of serial data communication, a steering column power assembly with
positioning motors and sensors, and a steering column tilt and telescope switch. The steering column
position control module will wake up either by the serial data or by the steering column tilt and
telescope switch.
Two position sensors are hall effect sensors and are used by the steering column position control
module. The steering column position control module provides a 5 V reference voltage and a ground
to both the tilt and telescoping position sensors. The sensor feedback circuit voltage varies from 0-5
V. Each sensor is part of the motor assembly. The steering column position control module monitors
the feedback voltage to determine the column position.
All DTCs and data from steering column position control module is communicated through the serial
data and stored in the seat memory control module.
GL
Ron
