Does anyone know what the valve springs specs are for the Gen V LT1 & LT4? So far I found the Spring height 1.90". I'm trying to find the spring rate.
Please Help
I searched everywhere and I could not find an answer. Only 2 places I can think of that may have an answer. There is @FYREANT here on the forum or you can maybe contact a speciality engine builder like WeaponX in Ohio. Try those.
I'll try, I want to upgrade the stock Valve springs and I'm looking for the similar specs. Thanks
THAT SAID, I do not have a spring tester available to me, and so I have not tested a stock/OEM "yellow stripe" or "blue stripe" spring. I do have several available ...
Which springs did you measure (GM P/N)? Yellow stripe? Blue stripe?
These were both blue stripe springs. They honestly seemed like they could have been the exact same spring. They were disassembled off of brand new LT1 and LT4 heads straight from GM.
Yes, LT1 and LT4 springs should be the same ... LT4 uses different valve(s) with different keeper/lock groove locations (I think), I presume mainly to handle the additional pressure on the face of the intake valve due to boost
Thank you so much for the link and time for posting it. I see you decided to use GM blue springs.
Were you able to find out the stock spring rate?
It is sad that trying to find a stronger easy drop in spring has to be a pain after 6 years. That was one of the good mods I had done to my stang after the SC install. Now my Vett is a ticking time bomb.
I found a few springs that I like, but they're all 1.80" install height. I found shims that will fit, I'm just concerned will that cause any issues. My first choice would be:
1. PSI-1511ML
2. PAC-1219X
It would (probably) work if shims that matched the available ID (that is increased due to the one-piece valve stem seal's OD) were available ... but all the shims I have seen are designed around standard valve guide diameters, or the valve guide boss diameter ... these are all smaller IDs than the valve stem seal OD. What you want/need is a shim that is designed with a larger ID to match the valve stem seal's larger OD, and that is something that the aftermarket doesn't seem to want to support.
The 1.870" installed height of the LT1 is greater than 1.800", so with the right shims you could achieve an installed height of 1.800", yes.
Going by the measured numbers earlier in this thread, the spring compresses 0.551" (the lift of the LT1 cam on the intake (and exhaust, IIRC) for a change in pressure of 210 bs (323lbs - 113lbs), for a spring rate of 381lbs/in or roughly 385lbs as you surmise.
I do not know if the cam lift is specified at the valve, or at the cam -- I think it's at the valve, so we can ignore the rocker arm ratio.
Reason: Corrected some stupidity on my part.
That picture of the valve stem seal standing alone illustrates the issue nicely -- compare its OD down at the bottom, to the OD of the "naked" valve guide to the right in that picture ... it's bigger than the guide's, and so you need shims with larger IDs to fit ... plus, the guide does not have any machined-in features to capture the valve stem seal, so you will be relying on friction alone to keep the seals on the guides if you toss the stock integrated seats/seals ...
And yes, PAC1215 was my main choice for a replacement spring.
