Headers or Manifold
Old Jul 13, 2020 | 09:59 PM
Jamil Kaine's Avatar
Jamil Kaine
2nd Gear
Default Headers or Manifold
I have a black C7 stingray and I have a e85 tune with intake and throttle body. I was thinking which one should I do first a MSD manifold or TSP headers
Old Jul 14, 2020 | 09:07 AM
Internets_Ninja's Avatar
Internets_Ninja
Do headers and a ported stock intake manifold. The MSD will make more peak power up top but lose some down low. It really isn't worth it unless you do a cam IMO.
Old Jul 14, 2020 | 01:51 PM
99vetteran's Avatar
99vetteran
What kind of power are you making now with the E85 and CAI? If your going to port the intake also do the TB. I'm doing a similar build with E and Cai, cat delete but using the stock exhaust manifolds. Gm did a pretty good job on the exhaust for the LT1s. On my Camaro I just sold I made well into the 700's on the stock exhaust with the 2300 Maggie, stock Lt1, did use Meth/water for extra fueling and Lingenfelter Big Bore Pump which was basically a modified LT1 Fuel pump a few years back.
Old Jul 14, 2020 | 05:04 PM
Dcasole's Avatar
Dcasole
+2 Headers and Ported Stock manifold
Dave
Old Jul 16, 2020 | 03:06 PM
tblu92's Avatar
tblu92
St. Jude Donor '13-'14-'15
[QUOTE=Dcasole;1601840541]+2 Headers and Ported Stock manifold
Dave[/QUOTE
+3 on above Look at MAP Performance for the ported intake manifold-
However I would start with the easiest mod 1st which is the intake manifold Then the headers
Old Jul 17, 2020 | 08:46 PM
Michaelh007's Avatar
Michaelh007
[QUOTE=tblu92;1601851680]
Dave[/QUOTE
+4 on the headers and ported gm intake manifold.
dont forget to protect those plug wires with heat sleeves.
To Headers or Manifold
