tpms sensor
Old Jul 29, 2020 | 09:39 PM
Stan0324's Avatar
Stan0324
Default tpms sensor
Need to buy a set for my 2015. The dealer seems a bit high. Local parts store sells multiple ones I think they are 4.33 and should be auto learn. Does anyone have any suggestions where to buy and possibly brand and model/
Old Jul 29, 2020 | 10:10 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
The C7 sensors have:
GM part# 13581560 2014 - 2017
GM part# 13598775 2018 - 2019.
The first # was superseded by the second #, but they are the same sensor.
Tire Rack sells Shrader 20223 for 2014 - 2019.
Rock Auto sells the Shrader 20223 for $22.79
The C7 tire pressure sensors transmit their data to the TPMS module on a frequency of 433MHz.
Elmer
Old Jul 30, 2020 | 11:16 AM
RacerRik's Avatar
RacerRik
Elmer
Elmer,
Good info except the two GM parts are not the same sensor. 13581560 will not work on 2018 or 2019 Corvettes. I know this from personal experience. 20223 parts work perfectly for all C7s and will auto sense when you drive the car - no programming or special learning modes required. .
Old Jul 30, 2020 | 11:40 AM
Z51C7's Avatar
Z51C7
If you're using Rock Auto, here's a 5% discount code:
12720121784680764
Old Jul 30, 2020 | 12:18 PM
mityaz's Avatar
mityaz
Buy OEM from rock auto. It's ACDelco with PN ending in 75. Track tested. work great.
Old Jul 30, 2020 | 01:00 PM
eboggs_jkvl
Moderator emeritus
Originally Posted by RacerRik
Elmer,
Confused???? I have them listed for 14 - 17 for one part number and 18 - 19 for another part number. Looking at the post I made it shows 2 part numbers for the model years.
Won't the 18-19 part number work on the 2014-2017 cars? You always use the latest part number for the car.
Elmer
Old Aug 3, 2020 | 09:02 AM
CraigStu's Avatar
CraigStu
I have no idea about the #s but when I got wheels and tires from Tire Rack they also installed sensors. They have been perfect. I switch tires back and forth between street and autocross and never see a light.
To tpms sensor
