Persistent Alarm - Coupe
Old Sep 11, 2020 | 02:25 PM
Bounty Hunter 6's Avatar
Bounty Hunter 6
Default Persistent Alarm - Coupe
I've read several other threads about the alarm persistently going off, but none of them address my issue, or were specific to the convertible that has a switch where the latch is. I have a 2014 Coupe and the alarm is constantly going off. Yes, I turn off the interior motion sensor, no I don't have a sunshade or anything else moving to set it off even when the interior motion is on. I can see my car outside of my window at work and it will just randomly go off. I look out the window and nothing. I don't keep my keys in my pocket thinking maybe when I sit down I trigger the alarm button. Nothing. I thought maybe when I changed the battery it would fix it, since my original battery was still in the car from 2013 and I have over 100,000 miles on the car. Nope. Brand new battery and it's still doing it. Sometimes it will go off every couple of minutes 3 or 4 times in a row until I just leave it unlocked. There has GOT to be someone that has figured out why TF this is happening!!! Doesn't matter if the roof is on or off; parked in the shade or not, etc. Has anyone actually diagnosed this issue before??
Old Sep 13, 2020 | 02:44 PM
Bounty Hunter 6
No one has this issue??
Old Sep 16, 2020 | 06:09 PM
Bill Dearborn's Avatar
Bill Dearborn
You probably need to have the codes read to find where to look. Normal OBD II reader won't read body codes so you need a tool with capabilities similar to the GM MDI tool.
Bill
Old Sep 16, 2020 | 10:41 PM
CodeWarrior's Avatar
CodeWarrior
Cruising
Perhaps the break glass detection for the rear window? See post below for another users detailed pictures. Might be something burned up or damaged back there.
https://www.corvetteforum.com/forums...post1599616049
To Persistent Alarm - Coupe
