Has anyone had or know of any issues or recalls associated with the electronic parking brake on the Corvette?
Had an issue where I manually engaged the parking brake in normal operation but it didn't actually engage, causing the car to roll.
Curious if anyone else has encountered this issue or knows of any defects or recalls.
Thanks!
Matt
Did you recently replace the rear brake rotors/hats with a non AC Delco brand? Sometimes there is a difference in the diameter of the inner brake drum in the hat. If the diameter is too large the parking brake may not hold well. When that happens the shoes need to be adjusted.
