Parking brake, set up correctly?
Old Nov 21, 2020 | 08:24 PM
BigBill94's Avatar
BigBill94
Default Parking brake, set up correctly?
Hi,
I have RideTech c7 based rear trailing arms on my '70 (C3) Corvette.
In order to run the c7 parking brake, the parking brake system has to be swapped side/side due to the caliper mount.
This is the driver's side, curious if I have the shoe adjuster set up correctly? Not sure if it needs to go in a specific direction. Since I don't have a C7 to look at, figured you guys might know?
Driver's side rear parking brake - C7 based RideTech C3 rear control arms
