Engine Compartment Ground Location?
Old Dec 17, 2020 | 04:24 PM
BarneyZ's Avatar
BarneyZ
Default Engine Compartment Ground Location?
I'm installing a couple of cameras and need a ground somewhere in the engine compartment, any suggestions?
Thanks!
Old Dec 17, 2020 | 04:27 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I grounded my camera on the stud ground sitting on the passenger fender well. Just to the rear of the air filter.
Elmer
Old Dec 17, 2020 | 04:29 PM
Keihin39's Avatar
Keihin39
There is a ground on frame rail drivers side right near brake anti lock pump block .stand at drivers side front wheel and look down at frame rail and you will see it it has a bolt with a ground wire attached
Old Dec 17, 2020 | 05:25 PM
BarneyZ's Avatar
BarneyZ
Elmer
Perfect! Thanks! Out of curiosity, what did you use for your hot? I've been planning on running from the rear box (slot 37) up to the engine compartment mostly because it needs to be switched. PITA otherwise. Vey open to further suggestions.
Old Dec 17, 2020 | 05:27 PM
BarneyZ's Avatar
BarneyZ
Thanks, I will probably try Elmer's suggestion as I need to run on the pass side.
Old Dec 17, 2020 | 06:46 PM
eboggs_jkvl
Moderator emeritus
I tapped out of the console cigarette lighter for a switched 12v. I tapped the M2W out of the fuse box in the engine bay, it was also a switched 12v.
ELmer
To Engine Compartment Ground Location?
