I am trying to fine out if anyone else has experienced this or knows if this is normal. I have a 2016 C7 Corvette. Today I was on the interstate traveling 70 mph when someone in the lane to the right of me changed lanes on top of me. I jammed the brakes the ABS kicked in and I barely avoided getting hit. I then stabbed the accelerator and the car fell on it face. It was accelerating slowly. I was then in the left lane of the interstate down to about 30 mph with traffic doing 70 mph coming up behind me and the car just didn't want to go. I tried letting off and accelerating again but it did the same thing. After about 10 or 15 seconds everything came back and the car took off. Is this some sort of limp mode the car goes in after an emergency? If it is I don't like it.
Yes I did the same think only I pulled over & killed the car let it set for about 10 good mins after cleaning my pants out.. It was good after the pull over & that. Robert
Pulling over would have been a good option but I couldn't. It was in a construction zone. I had a concrete barrier on my left side and traffic in the lane to the right, so I just had to deal with it. My original thought was I tried to accelerate too fast and traction control kicked in, so on the second attempt I eased into the throttle with the same results. If this is the way the car is programmed to act it is very dangerous and I don't like it.
Yeah doesn't sound right. At Spring Mountain owner school they had us do several emergency braking exercises. And we had to go into to full anti-lock mode, stomping on the brake with full force. Not once did anybody's car go into limp mode. They told us they wanted us to know instinctively how to stop the car in case we were to go off track. They said that In the past people would try to save it and trash the car. It's truly remarkable how these cars can continue to steer in full anti-lock brake mode at high speed. Even on wet pavement.
What you describe is very odd. I have invoked ABS suddenly with no ill effects.
My hypothesis is the event confused the stability control and traction control some how (wheels rotating at unexpectedly very different speeds, yaw sensor disagrees with steering angle, etc.). It may take a bit for the car to unscramble its brains under these circumstances.
If it does not happen again I would forget about it.
Thanks for the replies.
I remember the braking exercises at Spring Mountain, but we did not try to accelerate hard right when we came off the brake pedal.
I am hoping to determine if this is something that can be expected to happen coming out of an emergency situation, or if it was just a fluke incident.
Go out and intentionally invoke ABS a few times, including continuing to go straight and turning. My bet is the car will not go into any type of limp mode.
I had some time today. I tried several times to get the car to do it again, and could not. I tried emergency baking several times, and swerved during some of the attempts, and the car accelerated normally after each attempt. I am going to chalk it up as a fluke, and hope it doesn't happen again.
Any help would be appreciated.
Thanks.
Sounds like you triggered oil starvation protection. You can get this under sudden hard acceleration (with traction) or braking, or both one after another.
I forgot what sensor triggers this but it can happen when most of the oil pools at the back or front of the engine/tank cant remember the exact conditions but you can probably look it up on Google easily.
Did it come back on its own after a bit or did you have to restart the car to clear limp mode?
Oil starvation protection will reset itself when the condition clears, where other limp modes usually need some other intervention to be re-set.
it came back on it's own after about 10 to 15 seconds. I have the Z51 package, which includes the dry oil sump. I thought the purpose of this was to prevent oil starvation.
Excellent news!
I believe it was one of those rare odd things that happen only once.
It is, and it helps but even stock dry sump cars like Z06's have reported this on a drag strip with really sticky tires on launch. There are threads about it on this forum I just can't seem to find them or my memory is really bad...lol!
The oem dry sump system is nowhere as robust as the ones you find on a real race engine with oil scavenging points all over the engine.
I don't remember all of the details but there is something you can do in the tune to make it more tolerant.
I would not worry about it personally, the oem dry sump helps in this area but is not immune to physics (just like stability and traction control.) and has protections in place when the electronics cannot overcome the issue.
