C7 Bolt Pattern
Old Feb 12, 2021 | 12:30 PM
rickster1823's Avatar
rickster1823
Default C7 Bolt Pattern
Does anyone know if a 5X120.7 bolt pattern will fit on a 2018 Z51? Not many threads out there regarding this subject. OEM Bolt pattern for Stingrays is 5X120.65!
Old Feb 12, 2021 | 01:37 PM
laserdude2215's Avatar
laserdude2215
You must realize that the difference is only 0.05 mm. That's 0.002 inch! That's roughly the thickness of a human hair.
Old Feb 18, 2021 | 04:11 PM
Avanti's Avatar
Avanti
I've no idea what you are considering putting on your car, but there is much more to "correct" fit than bolt-pattern (which you probably realize). In any event, you need the same hub-hole sizes and adequate brake clearance, apart from wheel diameter, width, and off-set. Ever seen a wheel break or fly off at speed? Just be careful.
Old Feb 18, 2021 | 05:13 PM
Maxpowers's Avatar
Maxpowers
Lugs are cheap. I would stick with OEM spec.
Old Feb 19, 2021 | 11:37 AM
rickster1823
I ended up getting some forgestar 18X11 / +71 ET / OEM bolt pattern. Once they arrive and I get them mounted i will post some pictures to show the fitment.
To C7 Bolt Pattern
