Will not start
Old Mar 8, 2021 | 02:14 PM
Buckner21's Avatar
Buckner21
Default Will not start
If I drive my 2016 Stingray 30 or 40 miles and then stop, if I try to crank it again it won't start, I have to be jumped off. Has anyone else had this issue? Put a new alternator on it, had the battery checked, its ok. It can set 3 or 4 days in the cold and it will fire right up.
Old Mar 8, 2021 | 02:55 PM
Photomania's Avatar
Photomania
How many miles on the car? If you park the car for 20 - 30 minutes after it won’t start, does it start then? Does the check engine light come on? My first Corvette did something similar, but it was a C4. I replaced the main computer and insulated it and that solved the problem. Just a thought. Your situation is probably different.
Old Mar 8, 2021 | 03:05 PM
Buckner21's Avatar
Buckner21
It has 58,000 miles and yes, if you let it set a while it will start up but no check engine light.
Old Mar 8, 2021 | 03:16 PM
laserdude2215's Avatar
laserdude2215
You need to clarify this. Are you experiencing a crank no start condition or a no crank condition? Jumped off from how high? How much time later?
Old Mar 8, 2021 | 03:27 PM
Buckner21's Avatar
Buckner21
Slow crank to a click and after about and hour of sitting it will start.
Old Mar 8, 2021 | 03:42 PM
laserdude2215
Such a short drive typically wouldn't heat soak the starter enough to produce these symptoms, but I'm still going to suggest a starter replacement. The battery wiring from the under-hood aux fuse block to the starter would be another place to look.
Old Mar 8, 2021 | 03:43 PM
Maxpowers's Avatar
Maxpowers
Many have had the battery checked OK, but if your on the original, I would replace it.
Old Mar 8, 2021 | 04:49 PM
seniorstorekeeper's Avatar
seniorstorekeeper
I would agree with laserdude2215, sounds like a starter issue to me, what we used to call starter dragging. When it gets hot, vehicle will not crank but let it cool down, will crank just fine, is a starter issue.
Old Mar 8, 2021 | 04:55 PM
Bill Dearborn's Avatar
Bill Dearborn
I agree. It sounds like there is an issue somewhere in the wiring to the starter or in the starter itself. First, check to make sure the wires at the starter are fastened tightly and the connections are clean and free from any corrosion. If the problem still persists then it is time to remove the starter and have it checked out by a shop that can check starters.
Bill
Old Mar 9, 2021 | 05:20 PM
BELVIN20's Avatar
BELVIN20
If that is the original battery, I can almost promise that it is a battery issue, 2016, 5yr old battery, new battery before you spend starter money, & I have doubts the original alternator was bad, alternator & starter failure is rare these days. A 30 mile drive will not recharge even a new battery. Do you have a battery tender on your car when not in use?
To Will not start
