Taking the car to shop this week to see what is causing the lurching while driving,Changed plugs twice (different makes). Ran Royal Purple Injector in tank but still does it....They are going to put it on Dyno and put a load on it and that should tell what the problem is..If it is an injector and they can single it out should I just have them replace the bad one or spend big bucks to change all...My car is pretty heavily modified but not many miles on build...See Signature.....????....Thanks
A&A had me take the Big Bubba Blow off Valve apart and clean and oil the piston. That didn’t help 🙄 ...It’s a good shop so I’m sure they will figure it out. Thanks
