need help!!!
Old Apr 23, 2021 | 09:05 AM
army_man8200's Avatar
army_man8200
5th Gear
Default need help!!!
hello all really need help here, so i have a 2014 C7 automatic 3LT with 40k miles on it, dealer is telling me the ball bearings in the flywheel are bad and causing the weird knocking sound when the engine shuts off. Here is the fun part, they say outside of all warranties manufacture or extended and the entire drivetrain needs to be replaced as GM will not sell just flywheel. quoted me 5k for repair.
1. thought the automatic had a flex plate no flywheel?
2. can this be correct? the whole drive train not just parts or internals
thanks in advance this is such a headache and basically i need help with next step i cant believe at 40k i would need to replace a drivetrain
Old Apr 23, 2021 | 12:13 PM
laserdude2215's Avatar
laserdude2215
Please just take your car somewhere else!
Old Apr 23, 2021 | 02:15 PM
army_man8200
5th Gear
was hoping for in depth answer, that much was obvious
Old Apr 24, 2021 | 01:58 PM
0311 jarhead's Avatar
0311 jarhead
Veteran: Marine Corps
First off you dont have a flywheel, you have a flex plate. I never heard of ball bearings on a flex plate. The torque converter attaches to the flex plate.
I think the guy you talked to is a scammer. You cant get the entire drive train for 5K
Old Apr 24, 2021 | 03:18 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Yeah that sounds quite strange to me. I would go somewhere else. We can't hear or see the problem so in depth is hard to do through Text in a forums.. people are stating that this does not sound right, find a more knowledgeable dealer/repair shop in your area for a second opinion at the very least.
Old Apr 24, 2021 | 03:58 PM
RonC7's Avatar
RonC7
TAKE YOUR CAR SOMEWHERE ELSE!
A good dealer has some test equipment to locate where the noise is coming from.
The flex plate connects to the torque tube. The transmission is at the other end of the torque tube, in the rear, bolted to the differential.
There are bearings in the torque tube that can fail and make noise.
Note - there is a specific procedure to install a torque tube on auto trans cars that must be followed to avoid engine thrust bearing damage.
https://www.corvetteactioncenter.com...dure-1313.html
GL
Ron
To need help!!!
