Steering and stability control message after supercharger install
I just finished up installing my ECS supercharger install and everything seems to be done property but I’m getting a steering and stability control message. Also rear axle off?
I have no tune in the car yet because I will be loading it up and bringing it to get tuned. Could these messages have anything to do because I had to remove my steering rack to install the lower pulley. Does the steering need to be relearned or centered after unplugging and removing it?
Any help would be great, I hate to chase problems that aren’t there and just needs to be reprogrammed.
Is everything connected properly on the abs and steering? Did the wheel get turned when the intermediate shaft was disconnected? I’d suspect it has to do with one of those things.
I think everything is connected properly. As far as turning the wheel with the shaft being disconnected, I never unlocked the steering wheel only turned the intermediate shaft a little to get the bolt back in.
If that’s the case scan the car for faults. That should help narrow it down. Did you touch any ground connections during your install? Blown fuses?
