Exhaust question
Old May 23, 2021 | 08:55 PM
Molly815's Avatar
Molly815
Default Exhaust question
I have a 2015 Z06, looking to replace the OEM exhaust. My question is if I use stock headers and aftermarket x pipe would I need a axle back or cat back muffler system? And does that change if I want to replace the OEM headers too?
Old May 23, 2021 | 11:04 PM
96GS#007's Avatar
96GS#007
Aftermarket x-pipes bolt in place of the OEM x-pipe. You do not need to change anything else.
If you replace the OEM exhaust manifolds and cats with headers, then you'll need an x-pipe designed to work with the headers you buy. The mufflers will still be fine.
