Replace all hardware when replacing valve springs?
Old Jun 27, 2021 | 03:29 PM
carnate69's Avatar
carnate69
Default Replace all hardware when replacing valve springs?
I broke a valve spring on my c7 and plan on replacing all of the springs at once with GM blue stripe springs, apparently different from the yellow stripe based on the stripe color only? No idea if anything changed except the paint color.
Is there any issue to replacing all the retainers and keepers at the same time as doing all the springs? I’ve read you have to keep the OEM keepers in their correct spot when taking off and putting back so wasn’t sure if new keepers cause any issue with a worn in valve for 40k miles.
My thought is since one spring broke, the others are maybe on their way so let’s start fresh with everything.
Old Jun 27, 2021 | 03:59 PM
Dcasole's Avatar
Dcasole
Just keep the same retainers and keepers ....... no need to replace at all ..
Old Jun 27, 2021 | 05:14 PM
carnate69's Avatar
carnate69
It seems like cheap insurance to (already ordered them) so that’s why I was wondering. I understand the retainers and keepers really aren’t wear items?
Old Jun 28, 2021 | 12:51 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Unless the other parts are damaged I'd only replace the spring and locator/seal.
Old Jun 28, 2021 | 01:28 PM
Dcasole's Avatar
Dcasole
I agree .... in this case, if it ain't broke don't try to fix it
To Replace all hardware when replacing valve springs?
