Base Suspension Upgrade Question
Old Apr 28, 2023 | 06:09 PM
RacerRik's Avatar
RacerRik
Sway bars and other suspension parts are not going to increase your steering weight. Not sure what you mean my directional stability. The base Stingray is very stable in terms of mid corner balance. I expect that is what GM intended when they deleted the rear sway bar. Adding the sway bar to the base Stingray will actually reduce the stability which gives increased performance when driving at the limit (as in autocross or racing conditions - not street driving) - with greater risk of spinning the car. If by directional stability, you mean you want to reduce the floaty feel of the car, Z51 shocks will do that for you.
Old Apr 28, 2023 | 08:50 PM
hkfan's Avatar
hkfan
Can I just start with Z51 shocks and then later add the sway bar if needed?
Old Apr 28, 2023 | 09:02 PM
RacerRik's Avatar
RacerRik
You certainly can and in fact that is the best way to make changes. That way you get to see what the results are from your change. Please post back with your results if you do that so others can learn also.
Old Apr 28, 2023 | 09:17 PM
hkfan's Avatar
hkfan
Excellent. Would I just change out shocks or would I need new bushings or anything else?
also, any idea part number for Z51 shocks?
Old Apr 28, 2023 | 10:38 PM
RacerRik's Avatar
RacerRik
No need for any bushings - the shocks are complete units and they are easy to change. I do not know the latest shock part numbers. GM seems to change the numbers every year, but the actual parts do not change. No idea why they do this.
Rock Auto shows part # 84513884 for the Rear Sport Suspension (FE3) shocks. And 84513885 for the Front. FE3 is the designation for the Z51 Non-Mag Ride Suspension so that is what you want. They are only about $83 each.
Old Apr 29, 2023 | 06:26 PM
AnotherNorskie's Avatar
AnotherNorskie
I wonder if you should have this discussion with a shop which is skilled with making alignment changes for track drivers?
Old Apr 29, 2023 | 06:46 PM
hkfan's Avatar
hkfan
You bring up a good point. I was able to finally find a shop in South FL that has the C7 caster tool to handle the alignment. I plan to have them install the Z51 shocks and do the alignment.
Old Apr 29, 2023 | 07:45 PM
Random Dan's Avatar
Random Dan
Changing the shocks will not require an alignment afterward but it’s not a bad idea to have it checked. The z51 or Bilstein B6 shocks make a base FE1 vette feel so much more responsive and planted. For the cost and ease of installation, it should be one of the first things to consider. I went with the B6 set when one of my rear shocks sprung a leak years ago on my FE1 vette and never regretted it.
Old Apr 29, 2023 | 09:37 PM
AnotherNorskie
The key is to find a shop that understands more than just "align it so it goes straight" or whatever the shop manual states. My local shop can align to minimize tire wear, or for better turn-in, or for highway stability etc. if the vehicle supports those adjustments. If the stock car doesn't have the adjustments needed, consider aftermarket parts like adjustable length control arms, adjustable position shock mounts, etc.
Old Apr 29, 2023 | 09:52 PM
hkfan's Avatar
hkfan
Good point. My goal is the greatest amount of highway stability and steering weight possible. The light weight of the steering and on-center play, even in track mode, drives me crazy. I'm assuming caster is what is needed? Would I need aftermarket parts to maximize caster?
Old Apr 29, 2023 | 11:22 PM
RacerRik's Avatar
RacerRik
The C7 Corvette has fully adjustable suspension. You do not need any aftermarket parts. Steering weight, and to a small degree, stability will increase with more positive caster (top of steering center line is back farther than bottom).. The Corvette already has more positive caster than most cars. You could try maxing it out to see if you like it. That will result in a bit more inner tire wear due to more camber change when cornering (tires will "lean into" the turn more).
To max out caster, adjust lower control arm front adjuster to most inboard position as possible. Then set camber by adjusting lower control arm rear adjuster as needed to get desired camber. This approach will only allow a small amount of negative camber so this alignment will not be suited for aggressive driving. So it will be a trade off for you to get more heavily weighted steering at the cost of some cornering performance and additional tire wear.
Driving my own base Stingray, even in autocross events, I find the steering weight just fine and I certainly have no on-center play in mine. Perhaps, something is wrong with you steering rack? Or maybe you are just used to something different? What car did you drive before the Corvette?
Old Jun 6, 2023 | 12:38 AM
Itsmebryan's Avatar
Itsmebryan
Im in the same boat. This floaty up and down motion is unsettling at speed. I traded in a '08 pontiac Solstice GXP 5mt a '14 base 2LT 7M convertible with 16k mi. And I can say my Solstice inspired more confidence when you push it. I have a plan to get rid of the float and improve handling
1. The shocks Do I get the Bilstein B6 or the factory Z51 (FE3). Input on either will be appreciated. I like the ride of my car just not the up and down control.
2. Rear Z51 rear bar (no-MAG ride)
Hopefully this will make the car perform the way I'm look for.
Thanks for any input.
Old Jun 6, 2023 | 10:44 AM
  #33
RacerRik's Avatar
RacerRik
I have not used the Bilstein B6 shocks so i cannot comment on them. The OEM Z51 shocks are perfect in my opinion. And they are not expensive so I think that is your best option. Adding the rear bar will make the car ride stiffer. You should probably try just the shocks first and see if that gets the car where you want. You can always add the rear bar later if you want a stiffer ride and / or want more cornering capability.
Old Jun 6, 2023 | 03:12 PM
  #34
Itsmebryan's Avatar
Itsmebryan
I was leaning towards the Z51 shocks first. Is there much change in the ride with the Z51 shocks?
Old Jun 6, 2023 | 03:33 PM
  #35
RacerRik's Avatar
RacerRik
They are noticeably stiffer, but to me not harsh at all. It makes the car ride like you expect a Corvette to ride.
I suspect the B6 shocks are stiffer since Bilstein advertises them as a "performance upgrade" to the Stingray shocks - no mention if that means over the base or Z51 shocks - but they do list the Grandsport and Z06 for the same part number shocks. GM paid Bilstein to develop the Z51 OEM shocks. I doubt Bilstein spent a bunch of their own money to develop and test the B6 shocks to actually make them perform better on the Corvette. I would consider the B6 shocks to be more of a generic replacement versus the OEM shocks that were extensively tested for the Corvette platform. They could also be the exact same shock sold directly by Bilstein....
Old Jun 6, 2023 | 04:07 PM
  #36
Itsmebryan's Avatar
Itsmebryan
I was thinking the same thing about the Bilsteins. I'm ordering the Z51 shocks. I can get all 4 for $359.58 shipped. Hopefully that will get me where I want.
Thanks again.
Old Jun 6, 2023 | 04:16 PM
  #37
RacerRik's Avatar
RacerRik
Good luck with your upgrade and please report back here how it turns out so others can share the knowledge.
To Base Suspension Upgrade Question
Old Jun 6, 2023 | 04:25 PM
  #38
Itsmebryan's Avatar
Itsmebryan
They will be here next week and I will install the following weekend. Will report back with my impressions.
Old Jun 12, 2023 | 05:38 PM
  #39
Racer1735's Avatar
Racer1735
I ordered a set of z51 shocks over the weekend and they shipped out today. Should be in my hands this Thursday! Trying to find the front and rear sway bars/links/hardware for the rest of the suspension upgrade, but finding lots of 'out of stock', 'parts on backorder', etc. I have reached out to Cultrag, but no response yet.
Old Jun 12, 2023 | 07:28 PM
  #40
Itsmebryan's Avatar
Itsmebryan
I order my Z51 (fe3) shocks from rockauto and the got in early on Saturday and I installed them Sunday . So, far the ride is slightly firmer but, nothing drastic. It seems to have solve the floaty feeling. I'm going to hold off on the sway bar upgrade for now.
https://www.octanegm.com/ has the sway bar in stock and everything for the rrear is @ $167 front bars are about $90.
