Tire/Wheel Guru's Needed
Need your thoughts. please.
I'm running factory Wheels & Tires on a Z-51.
FRONTS 245/35 - 25.82" diam. on 19" x 8.5" rims
REARS 285/30 - 26.82" diam. on 20" x 10" rims
I'm wondering what issues, problems and/or differences I may have if I stay with the same REARS, but go with a 20" FRONT and narrower profile? See below
FRONTS 245/30 - 25.82" diam. on 20" x 8.5" rims
I found a rim that I really like, however it doesn't come in a 19"
Make sure the offset will clear the brakes. You can use https://www.willtheyfit.com/ to calculate what the difference is between your old setup and new
I agree. As long as the offset/back space is the same you will be fine. Same exact OD and same section width so you will have more difference if you change tire brand/model than from going 19 to 20.
