AFM issues '19 C7 GS
Old Jul 26, 2021 | 12:13 PM
brussotx's Avatar
brussotx
Cruising
Default AFM issues '19 C7 GS
My GS - with an A8 tranny - spends most of its time on the track. During a recent run at COTA, I had issues w/the car switching to V4 - in corners T1 and T12 (both "hairpin" turns) - despite using Track mode "race".
Is GM kidding? They're worried about MPG on a race track?? The switch is not seamless and eventually the CEL lit up - code showing issue w/the AFM pre-muffler valve - which messed up my afternoon.
My research indicates that the AFM is active in all modes with the A8 unless you use the paddles in manual mode. I have purchased the Range plug in and it seems to work well on the street - keeping the car in
V8 mode at all rpms and speeds. My concern is what will happen at track speeds. Is anyone using Range at the track?
Old Jul 26, 2021 | 04:26 PM
Mike@DiabloSport's Avatar
Mike@DiabloSport
Supporting Vendor
The Range will keep it off on the track.
You could also look into a tuner that can disable it, once its OFF in the PCM its OFF for good.
Old Jul 26, 2021 | 04:41 PM
BigVette427's Avatar
BigVette427
If you were on the track long enough to get a CEL for the AFM I'd suggest that your probably a good candidate for HPTuners and a good tune for your 19 GS. Since you were driving at COTA, PatG is well worth the short drive down to Victoria.
Old Jul 26, 2021 | 05:20 PM
MCK_Z06's Avatar
MCK_Z06
Common problem with cars with AFM actuators on track due to plastic parts being in the exhaust path.
They get too hot and the plastic sticks to the metal actuator wheel and they stick open or closed causing CELs and need to be replaced.
EDIT: forgot to add that its probably not AFM being "activated" in race mode, its the physical part failing and the causing the CEL.
Old Jul 26, 2021 | 10:44 PM
brussotx's Avatar
brussotx
Cruising
Thanks for the info, guys. I plan to use a tuner as soon as my warranty expires.
Old Jul 26, 2021 | 11:47 PM
MCK_Z06's Avatar
MCK_Z06
If you don't want to tune but want to get rid of the problem for good when tracking the car you can install simulators and remove the valve from the exhaust path without throwing codes.
Of course you still need to replace the current ones which are already damaged first.
Cheap....
AWE AFM Valve Simulators :: 2014-2019 C7 Corvette (phastekperformance.com)
Old Jul 27, 2021 | 04:14 PM
ErnieN85's Avatar
ErnieN85
Cheap....
I have a pair of them cheap $20 if you want them PM me
Old Jul 27, 2021 | 04:28 PM
BigVette427
If I ever pull the heads I will want to install Johnson 2110 lifters; maybe get rid of all that plastic and go with the ones with the link bars while I was at it. Of course, the whole AFM delete kit. Would also want some better springs; I loved the PSI valve springs that I had on my LS7 heads.
But I really don't want to remove my heads because then I would want to CNC port them for greater flows, and then of course if you're going to do that you're going to want to bump up the cam lift a tad bit to take advantage of those new flows. Just turns into a money pit!
Old Jul 27, 2021 | 05:22 PM
brussotx's Avatar
brussotx
Cruising
Thanks, MCK_Z06, simulators are a great idea. I will do the research. Thanks.
To AFM issues '19 C7 GS
