Oil on floor...
Old Aug 5, 2021 | 03:17 PM
azcanuk's Avatar
azcanuk
Default Oil on floor...
2016 Z06 Convertible, had a small amount of oil on the garage floor, passenger side, in front of the rear tire.
Are the coolers behind the wheels on the Convertibles (no upper cooling ducts) like they are on the Coupes? Do the cooler lines run over the wheel wells and along the outer side of the car?
Don't see any oil on the underside of car frame but haven't yet reached up into the openings under the car.
Thanks.
Old Aug 5, 2021 | 04:48 PM
ersatz928's Avatar
ersatz928
The coolers are in the same spot, coupe or convertible, behind the rear wheels.
Old Aug 5, 2021 | 08:27 PM
Avanti's Avatar
Avanti
Leaking shock, perhaps (?)... not unusual.
Old Aug 13, 2021 | 12:16 PM
Thomasmoto's Avatar
Thomasmoto
Default Z06
That's what came to my mind right off as well.
Old Aug 13, 2021 | 03:03 PM
Bill Dearborn's Avatar
Bill Dearborn
I sort of doubt it is due to a leaking shock. If the shock is leaking the oil is going to come down the shock to just inboard of the lower ball joint on the lower control arm and drop onto the barrel of the wheel. Maybe the wheel throws the oil around the wheel well when it is rotating but I suspect the oil is probably coming from the front of the car. The dry sump reservoir is about 6 ft in front of the rear wheel. If oil was spilled when oil was added to the engine the oil could travel along the frame/body and drip in front of the rear wheel.
Bill
Old Aug 13, 2021 | 06:09 PM
azcanuk's Avatar
azcanuk
No oil added.
Thanks.
Old Aug 16, 2021 | 04:30 PM
Bill Dearborn
Originally Posted by azcanuk
No oil added.
Thanks.
That doesn't mean there isn't some sort of leak in that area.
Bill
To Oil on floor...
