C7 throttle body swap issues
Old Aug 5, 2021 | 07:07 PM
Grand_Wish's Avatar
Grand_Wish
Default C7 throttle body swap issues
Just removed my Tony Mamo TB and went back to stock as I am getting ready to trade and have noticed the RPM's drop and then acel from 500 to 700 and then settle down several times when at a stop. I pulled the neg side battery after installing the stock and let it sit overnight and went out for a 20-mile drive with no changes. Should I pull the battery cable again? Thanks!
Old Aug 5, 2021 | 10:27 PM
Elk's Avatar
Elk
I suggest you keep driving it for a total of 100 miles or so, at all sorts of speeds and throttle positions. It takes a bit for the car to adjust.
Old Aug 6, 2021 | 02:40 AM
Tony @ Mamo Motorsports's Avatar
Supporting Vendor
That's interesting.....you did the reverse of what most folks do and had an issue
I agree with Elk in the respect that it needs more time to adjust to the different airflow of the stock TB, but a battery disconnect might help you get there quicker
Let us know how you make out
-Tony
__________________
Please take the time to also visit my website at www.MamoMotorsports.com
Old Aug 6, 2021 | 07:40 AM
Grand_Wish's Avatar
Grand_Wish
-Tony
Hey Tony,
Last night as a sanity check I decided to pull battery and then removed stock TB just to check everything out and reinstall. Today when I get home I will reconnect neg. cable and go for a drive.
I did see there was a relearn on the forum but never had to do this with your TB.
Would you recommend this? Thanks!
Idle for 3mins
Off 1 min
Idle for 3mins
Old Aug 6, 2021 | 09:12 AM
miami08VETTE's Avatar
miami08VETTE
Sounds and behaves like vacuum leak somewhere. Is the TB well seated. Is gasket in good shape? Sometimes the bolt tightening sequence and/or torque used will cause these type of issue. Good luck...
Old Aug 6, 2021 | 09:33 AM
Grand_Wish's Avatar
Grand_Wish
Will see. I did go back and check everything. When I get home I will connect battery and go for a drive. Btw no CEL .... Thanks!
Old Aug 6, 2021 | 03:01 PM
miami08VETTE
No CEL is a good sign. Pulling the battery for a bit worked for me when I had CEL after TB install. If you did the TB work with battery connected it would explain your situation. Good Luck...
To C7 throttle body swap issues
